Issue with the second NIC for IP Monitoring
I cnfigured IPCC Express 4.0(3) to have 2 NICs, the first with the IP @ 172.16.100.5 for normal traffic and the second with the IP @ 10.10.10.5 for Monitoring and Recording and connected to the SPAN port on the switch.
Recording and Monitoring worked the first time but now it doesn't.
Here a portion of the MCVD log :
70422: Aug 03 14:20:28.480 CEST %MCVD-ALARM_MGR-3-UNK:MCVD no connection to alarm service
70423: Aug 03 14:20:37.683 CEST %MCVD-ALARM_MGR-3-UNK:MCVD alarmwriter queue is full some alarms will be dropped
70424: Aug 03 14:20:37.683 CEST %MCVD-CVD-3-NODE_CONFIG_ERROR:Cannot retrieve node configuration: Exception=com.cisco.cluster.impl.cvd.config.ClusterConfigurationException: Node 1 computerName=IPCC1, ip=10.10.10.5 not found in <172.16.100.5>
70425: Aug 03 14:20:37.683 CEST %MCVD-CVD-3-EXCEPTION:com.cisco.cluster.impl.cvd.config.ClusterConfigurationException: Node 1 computerName=IPCC1, ip=10.10.10.5 not found in <172.16.100.5>
70426: Aug 03 14:20:37.683 CEST %MCVD-CVD-3-EXCEPTION: at com.cisco.cluster.impl.cvd.config.impl.ldap.NodeConfigurationImpl.getIPAddresses(NodeConfigurationImpl.java:548)
70427: Aug 03 14:20:37.683 CEST %MCVD-CVD-3-EXCEPTION: at com.cisco.cluster.impl.cvd.config.impl.ldap.NodeConfigurationImpl.readIpAddresses(NodeConfigurationImpl.java:508)
70428: Aug 03 14:20:37.683 CEST %MCVD-CVD-3-EXCEPTION: at com.cisco.cluster.impl.cvd.config.impl.ldap.NodeConfigurationImpl.init(NodeConfigurationImpl.java:228)
70429: Aug 03 14:20:37.683 CEST %MCVD-CVD-3-EXCEPTION: at com.cisco.cluster.impl.cvd.config.impl.ldap.NodeConfigurationImpl.<init>(NodeConfigurationImpl.java:101)
70430: Aug 03 14:20:37.683 CEST %MCVD-CVD-3-EXCEPTION: at com.cisco.cluster.impl.cvd.config.impl.ldap.ClusterConfigurationImpl.init(ClusterConfigurationImpl.java:287)
70431: Aug 03 14:20:37.683 CEST %MCVD-CVD-3-EXCEPTION: at com.cisco.cluster.impl.cvd.config.impl.ldap.ClusterConfigurationImpl.refresh(ClusterConfigurationImpl.java:370)
70432: Aug 03 14:20:37.683 CEST %MCVD-CVD-3-EXCEPTION: at com.cisco.cluster.impl.cvd.LDAPMonitorThread.monitorLDAP(LDAPMonitorThread.java:96)
70433: Aug 03 14:20:37.683 CEST %MCVD-CVD-3-EXCEPTION: at com.cisco.cluster.impl.cvd.LDAPMonitorThread.run(LDAPMonitorThread.java:80)
70434: Aug 03 14:20:37.683 CEST %MCVD-CVD-3-EXCEPTION: at com.cisco.executor.Thread.run(Thread.java:539)
70435: Aug 03 14:20:37.683 CEST %MCVD-CVD-3-EXCEPTION: at com.cisco.executor.impl.ExecutorStubImpl$RequestImpl.runCommand(ExecutorStubImpl.java:684)
70436: Aug 03 14:20:37.683 CEST %MCVD-CVD-3-EXCEPTION: at com.cisco.executor.impl.ExecutorStubImpl$RequestImpl.run(ExecutorStubImpl.java:480)
70437: Aug 03 14:20:37.683 CEST %MCVD-CVD-3-EXCEPTION: at com.cisco.executor.impl.ExecutorStubImpl$RequestImpl.run(ExecutorStubImpl.java:756)
70438: Aug 03 14:20:37.683 CEST %MCVD-CVD-3-EXCEPTION: at com.cisco.executor.impl.ThreadStubImpl$RequestImpl.run(ThreadStubImpl.java:563)
70439: Aug 03 14:20:37.683 CEST %MCVD-CVD-3-EXCEPTION: at com.cisco.util.ThreadPoolFactory$ThreadImpl.run(ThreadPoolFactory.java:777)
What may be the cause of the problem?
Re: Issue with the second NIC for IP Monitoring
In the registry I configured
- HKLM\software\Spanlink\Site Setup\IOR Hostname with the first NIC ip address : 172.16.100.5
- HKLM\software\Spanlink\VOIP Monitor Server\config\Monitor Device\ with Splkpc_{the value for the second card}
But when I try the "ping IPCC1" I always have the resolution to the IP address of the NIC used for Monitoring.
I verified first in the registry keys, second, with the POSTINSTALL utility. All seems to be ok but I don't understand why when I ping IPCC1, I have the name resolution to the ip address of the monitoring interface.
I disable this NIC and then enabled it so the server begins to reboot because of a node manager failure.
Does anyone have an idea about this problem?
I tried to disable the second NIC, so the CPU usage raised to 100%. I restart the server so it began a cycle of rebooting with, in each time, a Node Manager service Failure.
To workaround this issue I diabled the second NIC and now I have no monitoring.
I resolved the problem of the second NIC but I still not hear when monitoring.
Anyone can help me ?
What's the vendor of NIC's Agents ? I have a similar problem and the NIC from Agent's Desktop had to be updated.
Luis.
I don't think it's an agent's NIC problem since I'm not using Desktop monitoring. From the SPAN port (on the Catalyst 3750 Switch) I'm monitoring directly the ports on wich the IP Phones are connected.
BR
could you inform me How did you solve the problem of the second NIC card?
When enabling the second nic on uccx 7.01 the node manager fails. How can you get it to work?
thanks,
Met.
OK, the problem is the binding order. Frontend NIC must always be the first.
199
