IVR and ICD interaction- Pls Help
I have setup and tested AA and ICD in CRS independently but was unable to integrate these two yet.
I want to do a basic language selection and select agents according to the selected language.
can anybody help me where to go next? some thing about IVR and ICD integration?
VIP Super Bronze
Re: IVR and ICD interaction- Pls Help
Well the ICD part is pretty simple: When you want to locate an agent for the call, add the Select Resource step and specify the CSQ you want.
In a multilingual scenario, you will likely have a CSQ for each language (i.e. salesEN, salesES, etc).
Please remember to rate helpful responses and identify helpful or
Since this language selection and queuing needs big learning curve and time, I just thought to combine default aa and icd scripts. when you press 1 for language 1 it will trigger another application and use csq in that. this is what i imagined to do but no idea if it works.
Jonathan, thanks, I posted another question and i saw your reply. you explained how to use set step etc.
Unlike other cisco stuff, self studying alone cant help me on this it seams. Bothering you all for every thing is also not possible !
Can any of you can suggest good way to get out from this? good book, internet reference or even a instructor led course?
125
