IVR Prompts Recording- noise after converting to Cisco format
We got some IVR rompts recorded by a professional vendor who recorded the prompt in the following format:
bit rate=705kbps
Audio Samle Size=16bit
Channels=1(mono)
Audio Samle Rate=44kHz
Audio format=PCM
Since this format is not supported by cisco, I had to convert it to cisco format using Windows XP Sound Recorder.then the format is the following after conversion:
bit rate=64kbps
Audio Samle Size=8bit
Channels=1(mono)
Audio Samle Rate=8kHz
Audio format=CCITT u-law
But after conversion I noticed the change in clarity, and can hear a hissing noise while playing this prompts.
Q 1)Can I get rid of the disturbance/hissing noise by using some other player/convertor using some other utility for conversion?
Q 2)What if I ask the vendor to record again dirctly in 8kHz, 8bit mono..Will this make any difference in clarity , since ultimately the result is 8 kHZ 8 bit mono?
I want to get avoid getting back to the vendor...
Pls advise..
Re: IVR Prompts Recording- noise after converting to Cisco forma
Do not use Windows prompt recorder to convert it. Use something like sound forge, audacity, or goldwave.
david
Sorry, now trying audacity,, can you tell me which options to use for conversion?
CCITT u-Law, 8kHz, 8-bit, Mono 7 kb/sec.
david
You should also be able to use the MOH audio translator service on callmanager (UCM). This will transcode and format the audio file into a compatible format. There is additional information in the srnd.
robb
Will the sound quality be better if the prompts are recorded directly in :
bit rate=64kbps
Channels=1(mono)
than converting from the following:
bit rate=705kbps
Channels=1(mono)
Audio format=PCM
or technically this makes no diffrence?
recording them directly will be the best, but honestly it might sound very similar if you just convert them.
david
Green
Redigitizing always introduces noise. You may not be able to hear it over the phone though.
Geoff
Friends,
What is your experience with this kind of a problem in the past.
1)When you give order to the vendor for recording IVR prompts to be used for IPCCX, in which format do you ask the vendor to record and how is the quality after that?
2)By any change on the IPCCX server, can we increase the playing quality to a higher format(may be somewhere in the registry or something like that).
561
