Attention: The Community will be in read-only mode on 12/14/2017 from 12:00 am pacific to 11:30 am.
During this time you will only be able to see content. Other interactions such as posting, replying to questions, or marking content as helpful will be disabled for few hours.
We apologize for the inconvenience while we perform important updates to the Community.
Jtapi Client problem again UCCX 5.02(SR1) and CM 6.12
Hi All,
I'm running UCCX 5.02 with CM 6.12. I've read through the forum with regards to the above issue and most point in the direction of copying certain Java files to the winnt directory if it is not already there. The thing is, the winnt directory with the java folder is already there with the necessary jar files. So after i log in as Administrator in UCCX, it prompt me to resync the jtapi client. And right after that (after clicking "OK") i get a blank screen which means I cannot do any resync or any UCCX operations. I've attached the log file Any suggestions would be most appreciated.
1 REPLY
Silver
Re: Jtapi Client problem again UCCX 5.02(SR1) and CM 6.12
It is necessary to verify the version of the JTAPI client on both the CRS Server and the Cisco CallManager are the same? If the JTAPI client(s) are different, several problems can arise.
119
