Community Member
Many Agents less phones
I have 50 agents in my center and 12 phones with 2 line capacity (7940)
what is the best practice for every agent having ICD ext on the phone or what is practice in this kind of cases when there are more agents then phones!! Besides obtaining more phones?
Thanx
Vlad
1 ACCEPTED SOLUTION
Re: Many Agents less phones
Agents using CAD and IP Communicator can use ExtensionMobility. This allows multiple agents to use the same phone—but only one at a time.
The agents must first log into CallManager using the CallManager Extension Mobility feature.After logging into CallManager with Extension Mobility, agents can log into IPCC Express using CAD
Community Member
I wanted to avoid Ext mobility, cause for my users is too complicated to log on to Windows then to Phone (Ext mobility) and then to CAD!!
But i'll try to persuade the CEO!!!
Community Member
We are facing the same situation
Customer don't like to have dual logging ( Ext. mobility + IPCC login )
Do u have any solution for this issue ?
Mohamed
Community Member
Here's how i soved it
I have 10 phones and lots of agents working in shifts
So i created users agent1, agent2... agent10
So if someone is seating on PC 1 he logs as agent1
and if i need info on some user, i track e.g. agent1, what windows account was logged at particular time on PC 1
Cheers
Vlad
159
