09-08-2013 08:56 PM - edited 03-14-2019 12:23 PM
Where can I find for a given installation the max no of calls that can queued for given ICM system.
09-08-2013 09:33 PM
Please refer the below link..
Gnan.
09-09-2013 11:44 AM
Well I did look at that doc. Yes, it talks about max number of queued calls being half the number of agents etc. Well I have scenario where say there are only 2 agents in lab and I could still simulate 10 calls in the queue. However is there a restriction in the system where it would not explicitly allow the calls to exceed certain threshold or would drop the call etc.
The only check/restriction, I have done is to set it in the script.
09-09-2013 02:46 PM
09-11-2013 10:06 AM
So are you then saying that there is no system built check for max no of calls that can be queued in ICM ? (license wise or otherwise )
I put a check in script anyways, but want to know if there is a limitaion on the system side.
09-11-2013 10:29 AM
Its depends on deployement type and hardware. Please refer the below link page number 25 for more info.
Gnan.
09-11-2013 10:44 AM
I looked at that but I think the answer is still not well defined. It talks about max call per second.That means that it can receive 300 max calls per second in ICM/IVR system. It does not say anything about how many concurrent calls can sit in the system and be queued.
For example on IVR side, we clearly know that it can support X no of max concurrent calls or whatever the figure may be based on ports. However for queued calls in ICM, it does not seem to very obvious. Unless I am missing something here.
