Media routing PIMs not going active
The only error message I get are from the Dialer stating that Media Routing PIM is not connected. Any thoughts?
Bruce Finney
1 REPLY
Re: Media routing PIMs not going active
Hi Bruce,
Have you configured MR PGs in the PG explorer on AWS? You will also need to add MR PGs and relevant dialer port range under Configuration Mgr > Outbound Option > Campaigns > Dialer
HTH. Please rate all helpful posts.
Sulabh
339
