Mobile Agent Issues with CAD
Guys,
I am having the oddest issue and it happens in nailed mode or in call-per-call mode. When the call finally transfers to an mobile agent (My cell phone) right when I pick up the call I hear music on hold. The original caller hears silence. This happens everytime, this is my first time configuring mobile agent. It sounds like a wierd signalling issue. Any ideas are greatly appreciated!
Cheers,
Chad
Re: Mobile Agent Issues with CAD
http://www.cisco.com/en/US/docs/voice_ip_comm/cust_contact/contact_center/cad_enterprise/cadenterprise7_2/user/guide/cad72ug.pdf
Page 36 shows a similar type problem, I think that the CCM is having problems connecting the calls, and thats what is happening. Because i get this in nailed or call-per-call and when making or recieving a call.. I have an interesting setup
(CCM Sits here) H323 Gateway 2851 PRI (QSIG T1, network side) -> Cisco 3825 H323 (QSIG T1, User) then it goes out a primary-ni T1 to the telco... So I have this trunk to deal with and I am not sure how to verify that this isn't the cause, because I suspect it is... I also seem to be having spuratic calling in and out.
Cheers,
Chad
here is an ISDN debug..
000232: *Jul 4 04:11:13.123: ISDN **ERROR**: Module-CCPQSIG Function-CCPQSIG_
CallConnected Error-Unknown event 0x58
000233: *Jul 4 04:11:13.127: ISDN **ERROR**: Module-CCPQSIG Function-CCPQSIG_
What could that mean? Also the mobile agent gets rung, its just its automatically getting MoH and when I end the cal in the CAD window, the caller gets disconnected and such, also they can get moh / no moh through hold/unhold on cad. Seems its only the PSTN agent that has issues..
Blue
Chad, did you ever get this fixed? I am having the same exact issue.
I had a similar issue with mobile agent. When configuring the agent local and remote CTI ports you should omit MOH sources on the remote CTI port. I believe CM has a default one in the end so you have to set them to a silent moh file.
I found that by adding the following statements under the dial peers for the H.323 gateway I was able to resolve a similar problem:
Dial peer to relay call from R1 to R2
dial-peer voice 840 voip
voice-class codec 1
voice-class h323 1
dtmf-relay h245-alphanumeric
progress_ind setup enable 3
no vad
Dial peer to route out to PSTN
dial-peer voice 940 pots
progress_ind alert enable 8
forward-digits all
467
