Monitoring and Recording 8.X with UCCX 8.5 - Installation issue
Dear all,
I'm trying to install the Workforce Monitoring and Recording software in a virtual server with W2003 Server R2 + SQL Server 2005 SP2.
When the Monitoring & Configuration Setup it's opened and The Monitoring and Recording CTI Service window appears I fill de gaps with the IP of the UCCX nodes and click next button but appear this error and I can't finish the installation process.
"JTAPI Installation Error
The following installation errors occurred:
Cannot find SQM CTI Server profile for ip X.X.X.X> or hostname."
What can be the problem?? I need fix this problem asap.
Thanks & Regards.
1 REPLY
Hi Eduardo,
QMPI2021:
Text:Cannot find SQM CTI Server profile for ip or hostname .
Type:Error
Add’l Info:The application could not find information in Directory Services for the local QM CTI Server.
Action:Verify that a QM CTI Server was defined for this server in Site Configuration.
Reference:
http://www.cisco.com/en/US/docs/voice_ip_comm/cust_contact/contact_center/workforce_optimization/qm_2x/reference/guide/qm26ecd-cisco.pdf
Hope it helps.
Anand
Please rate helpful posts by clicking on the stars below the right answers !!
788
