11-26-2010 08:40 AM - edited 03-14-2019 06:57 AM
I have UCCX 8.0 SR2 installed where my script
is utilizing an XML file with 240 area codes. The script queries the Calling Number against the retrieved data from the returned data of the XPath. Therefore, in my script I have set Enterprise data for a variable called "Unknown" for calls that have not been defined by area code in that file which is then sent to a single queue. My customer does not have a the option to perform percent allocation in the cloud nor are they using Callmanager/gateway to perform this type of distribution since the analyzing of the area code is done at the script level.
I need to find a way to distribute these calls between two queues evenly within the scripting. For example for every odd numbered "Unknown" call the call is sent to the queue B and every even numbered call is sent to queue A. How can I script for this in UCCX 8?
11-26-2010 09:03 AM
What we did is to count the number of calls handled by these CSQs. Then do a MOD by 2 on this "count1" (1 to include the current call) to find if it is even or odd and then send to the respective CSQ.
11-26-2010 09:18 AM
What is 'MOD' mean?
11-26-2010 10:10 PM
MOD is the Math MOD function, where you look for a reminder to determine you next step.
11-27-2010 10:29 AM
Smile.
"Remainder"
Geoff
