Need Help in Duplex PG setup
I am trying to setup a Duplex PG.
PG1A --> CUCM Pub 142.11.64.21 (one cluster)
PG2A --> CUCM Pub 142.11.64.21 (2nd cluster).  (we are not using single cluster)
IN PG Explorer
- PIM - CUCM1 - Logical ID: 5000 Periphera ID 5000
- PIM - CUCM2 - Logical ID: 5001 Periphera ID 5001
CGA is installed
now my primary PG is online and all Active status.
When I enable Side B PG2A it stops running all the processor in PG.
Just want to understand how Duplex PG works and how each side knows which one is the backup.  When I setup PG1 on SideA, to make it duplex should I choose PG1 on sideB with same DMP 1?
Re: Need Help in Duplex PG setup
What is the version of ICM? Also, please refer to the below link which would help you.
what is the meaning of "We are not using single cluster" so do you mean to say you have different jtapi users for the mentioned call managers
https://supportforums.cisco.com/docs/DOC-1374
Please rate useful posts
Dass
Green
Oh boy. I would not be pointing any JTAPI connections at a publisher, that's for sure. Let's say you have cluster CMA and CMB.
PUBA, SUBA1, SUBA2
PUBB, SUBB1, SUBB2
I would have:
JTAPI gwy PG1A -> SUBA1, JTAPI gwy PG1B -> SUBA2
JTAPI gwy PG2A -> SUBB1, JTAPI gwy PG2B -> SUBB2
Then it is not set up correctly. Go over the settings in Setup. Check the IP addresses of the private connections and to the central controller. Both A and B must be DMP2 for PG2.
Geoff
339
