Need help on script.
esa786_2
Hi. I need to know difference between the two scripts. I have attached the screen shots. pls explain. The first one i took it from IPCC ENT and second script is from IPCC Express. what is the difference. how to create it. I know ipcc exp script is through Script editor. But what about the first one,how to create, any documents.
regards
esa
Here is a basic document for ICM Enterprise Scripting: http://www.cisco.com/en/US/docs/voice_ip_comm/cust_contact/contact_center/ipcc_enterprise/ipccenterprise7_0/user/guide/ipce70sg.pdf
You can get detail of the nodes with some example scripts at the end of IPCC Enterprise/ICM Scripting here.
6 Replies 6
Hi. Thank you for your reply with link. it was useful. where to find the script editor. It is coming along with the ICM server like IPCC express. Regards
gem
Script Editor comes as part of the UCCE Admin Workstation installation.
C.
Thank you Corey.It is nice of you to answer.
esa
No worries at all Esa.
C.
