Need help to create a simple formula in icm routing script.
Hi friends
someone can help me to get better idea about ValidValue() built in function ?.can we use it like
ValidValue( ValidValue( ))  .. ?
Letme explain my exact requirement .
1 , storing external numbers to peripheral variables with the help of set node .
Peripheral vaiable 1="0001234567890"
Peripheral vaiable 2="0002234567890"
Peripheral vaiable 3="0003234567890"
2 , changing the value of 'caller enter digits' to 1-3 based on scripting logic .
3 , using peripheral variable 5 to store the peripheral variable number dynamically with the help of set node.
   concatenate("Call.PeripheralVariable",Call.CallerEnteredDigits)
4,using set node to fetch the value of correspoding peripheral variable (1-3 )
ValidValue(Call.PeripheralVariable5,"")
5,configured peripheral variable 5 in label node to route calls to corresponding external number  .
Current issue is step 4 is not working properly or need to use different formula , PV is not fetching the value stored on PV (1-3 ) , its simply showing
Peripheral vaiable 1 ,Peripheral vaiable 2,Peripheral vaiable 3.
Renni
1 ACCEPTED SOLUTION
Why do you need ValidValue?
If you're having problems with the approach above, why don't you just do something a bit more straight forward?
if(call.ced="1",PV1,(if(call.ced="2",PV2,(if(call.ced="3",PV3,"CED Not valid)))))
david
david
Thanks David , it worked fine.
236
