Need Script Help w/String Compare
I am a basic script writer and have not needed to use Java. I now have a need to find strings that are six characters (digits) long and begin with a "1". Using if VAR == "1....." doesn't work. Does anyone have a simple solution for this simple string compare? Do I need to use Java? Example please?
Re: Need Script Help w/String Compare
Found it! String methods under the If Step:
If String.StartsWith("1")
VIP Super Bronze
Yep.
You can check length with the .Length(6) value.
((variable.StartsWith("1")) && (variable.Length(6)))
142
