Outbound Dialer 7.0 problems
We are trying to install Outbound option for IPCC Enterprise 7.0 and we are having some problems with it. Our setup is as follows
Server 1 : Rogger 7.0 with SR4
Server 2 : CCM PG, VRU PG, CTI Server, CTI OS with SR4
Server 3 : AW/HDS SR4
Server 4 - Dialer, MR PG Sr4
CCM -5.0
We have installed everything as specified in the installation document, but when we start the Dialer, we see the followig in the command window
[lab1.Dialer.BADialer][CM-A][CTI-A][Ports C:4,R:0,B:0][MR-A]
As you can see, the Dialer ports are not getting registered. We added these dialer ports in Call Manager as Standard 30 VIP phones and they also show up as registered in the Call Manager. We added these phones to PGUser as well.
Yet we don't see these ports registered in the dialer window and so we are not able to get the Outbound working. Any clues as to what we are doing wrong here?
We are getting the following error in the Dialer as well as the CTI Server
Trace: (CLMGR) CTI Query Device Information Request, invoke: 4423, port: 003, instrument: [1004]
Trace: (CPORT) SetState, port: 003, state: PORT_WAIT_FOR_QUERY_DEVICE
Trace: (CLMGR_IP) Control failure event, port: 003, id: 1000004423, failure code: 13 [CF_INVALID_CSTA_CONNECTION_IDENTIFIER], peripheral error code: 10137 [C_??CAUSE??]
1004 is one of the Dialer ports and when the Dialer communicated with the CTI for this port, the above mentioned error occurs.
Gokul
Re: Outbound Dialer 7.0 problems
Check the Peripheral selected in the Dialer setup in Configuration Manager
I did and we did point it to callmanager PG.
Gokul
If you manually added the dialer ports on CCM at times they won't register or work properly. Try creating them first under Outbound option > Dialer > Export the ports in a .csv file and then import this .csv file via BAT in CCM. After that associate it with pguser.
HTH,
Sulabh
Hi Sulabh,
Initially we manually added the ports. Then we faced this problem we deleted those and added these ports via export. Still we have that problem.
Gokul
Are the dialer ports associated to your pguser?
Sorry, noticed you said you did. Try cycling CTIManager on the Callmanager as well as the dialer and PG. Also, verify that the pguser name/password matches between CallManager and the PG.
We have cycled these a lot of times :(
Gokul
Hi All,
We finally figured out the problem. There were a couple of issues basically.
1) When we added the dialer ports in config manager->dialer, I believe the device targets for these ports need to be added manually. This did not happen.
2) So we went ahead and added the device targets manually. Still it did not work. We were suggested by TAC to add the following line in the configuration parameters in the Device target for each of these ports
Configuration Parameters: /devtype monitorphone /dn 1004 /monitor Periph# i.e in our case one of the dialer ports was 1004 and our CCM PG id was 5000. So our config parameters looked like this
/devtype monitorphone /dn 1004 /monitor 5000.
Once we did this, the ports got registered and it worked like a charam :)
Gokul
Strange, those should have been added automatically when the dialer ports were configured. By the way, I strongly suggest applying the 7.1.4 patch, there are numerous dialer fixes (Its simple to patch just like SR4).
I have 7.0. Can I apply a 7.1.4 patch directly or would I need to upgrade to 7.1 and then apply the patch?
Gokul
Gokul,
Disregard my last thread....I didn't read further down to see that you have resolved the problem with the port registration. But in regards to your question, yes you can directly apply the 7.1.4 patch to the 7.0 install. There are lots of dialer fixes in 7.1.4 too.
Hiep
Gokul,
I am sure you have done this, but have you checked to see if you have defined the ports in Configuration Manager? Also have you associated the dialer ports to the PG User that you have defined?
Hiep
Hi Hiep,
Thanks for the tip on upgrading the Dialer. Will do the needful.
Gokul
I currently have the same issue, but the suggestions didn't worked for me, i noticed that on CUCM the ports are registered, but on the Dialer process i can see the ports just configured but not registered.
So i used dumplog to open the dialer logs and found the same error:
If there's any other suggestion, please let me know.
Claudio.
Just to let it documented,
I've noticed on CUCM that when i imported the file with the template i created it was not creating the first port on the list, so i deleted the first port on the list of the dialer and cycled the Dialer process and the next time Dialer process restarted the ports was registered.
One important thing is that you must have a minimum of 4 ports on the dialer, other way it won't sabe your configuration.
Hope this helps someone else in the future.
Claudio.
1301
