Outbound ECC Variables problems in IPCC 7.0
When I trying to get ECC Variables in ICM Script configured for outbound campaign I get following trouble:
I initialized node "Set Variable" with value: ?Call.PeripheralVariable2= Call.BADialedListID? But in result at CTIOS Outbound Option Softphone I see Call.BADialedListID but Call.PeripheralVariable2 is not initialized . I trying all other Outbound ECC Variables but result is the same . On the other side ? when I use custom ECC Variables (with ?user? prefix that I defined in ICM) , everything works correctly. i.e. node ?Call.PeripheralVariable2= user.UserVar? with previously deifned ?user.UserVar? works correctly.
-- best regards, Igor
1 REPLY
Silver
Re: Outbound ECC Variables problems in IPCC 7.0
ICM 5.1, 6.0, 7.0
CTI OS Server 5.1, 6.0, or 7.0.
If a monitor mode application that uses a wildcard in it's filter is disconnected, events containing the field specified with the wildcard will not be forwarded to other clients.
For example, if the filter is
MessageID = 10,13,15,23,24;DeviceUniqueObjectID = device.5000.1*
events containing DeviceUniqueObjectID will not be sent to clients after the monitor mode application has been disconnected.
Workaround:
Cycle CTI OS Server after a monitor mode application with a filter meeting the criteria described.
IPCC troublshooting:
http://www.cisco.com/en/US/products/sw/custcosw/ps1844/products_tech_note09186a00800b6a82.shtml
212
