Possible for two people to monitor (listen) to agent calls from same pc
Yort Mantup
Level 4
Level 4
CUCCX 5.0
I have a request to allow two supervisors to sit in the same room and from the same pc listen/monitor agent calls for audit reasons. Currently each supervisor uses a USB headset for this function. We tried plugging in two headsets but it does not work. Is this possible? Can the call be monitored over speakers?
Jonathan Schulenberg
CSD is just using the default Windows sound device. Feel free to try/use anything you want.
safety2008
Level 4
Level 4
not sure about the two usb's. but they make a y connector for the h/s for applications like this.
