Problem on the CTI
Hello all,
We are facing a problem on the CTI, whenever an agent tries to login to his CTI Agent Desktop, the name of a differentt agent appears and the data is saved as if the wrong agent was the logged in agent.
This problem is occuring for just one agent.
Has someone encountered a similar issue?
Any help would be greatly appreciated.
Thank you in advance.
Lara Noueir
  • Contact Center
Problem on the CTI
We are working on a UCCE 9.0 system
Re:Problem on the CTI
can u try deleting the agent and recreating it?
Sent from Cisco Technical Support Android App
We cannot delete the agent and recreate him because we are afraid to lose data needed to generate reports about his performance.
Problem on the CTI
It sounds to me that this agent is not using the right ID, can you post a picture of both agents in config manager?
david
Re: Problem on the CTI
Hi David,
Mohamad Othman is appearing as Charbel Geagea, and you can find attached snapshots of both agents in the Configuration Manager.
Sorry Mahmoud Othman
Did you generate the Agent ID youself or did ICM create it for you?
Also, do you log in using login name or Agent ID?
The ICM creates the Agent ID and the agents log in using their login names
Just a thought.. can you try changing the agent ID of the agent who has the issue? let it start with 5 for instance or something... and then try logging in again...
the configuration looks normal, nothing strange about it... the only thing i see is that the agent IDs are similar (with the exception of last digit).. so, maybe, just maybe, there is a bug that causes them to overlap or something
164
