Users might experience few discrepancies in Search results. We are working on this on our side. We apologize for the inconvenience it may have caused.
Problem to unistall Cisco Supervisor Destktop
Hi Guys,
My Customer have a IPCC 5.0.2 Rebuild 45. After install this release, the CSD had change, because, CSD was with another version. Our Customer uninstall the previous version and did download of plugin the last version, but, It is presenting error. Are there any procedure to unistall the previous version?
Thank You,
Wilson Santana
Everyone's tags (1)
1 ACCEPTED SOLUTION
Re: Problem to unistall Cisco Supervisor Destktop
Hi ,
Sometimes uninstalling the CAD from add/remove programs does  not remove some of the components and we need to manually clear some of the registery keys.
Here is a link for the document that will guide to maually remove CAD.
http://www.cisco.com/en/US/products/sw/custcosw/ps427/products_tech_note09186a00807835e3.shtml
Please rate all docs.
Rajiv
Hi ,
Rajiv
Hi Hajiv,
This documment refer the version 4.0.x. Is it used too to version 5.0.x?
Thank You,
Wilson Santana
Hi Wilson,
The document also applies to 5.x
Rajiv
341
