Problem with Agent based campaign
Dear All
I am facing an issue with agent based campaigns on a multi dialer enviornment. We have three dialers running and IVR based campaigns work just fine on them.
Agent based campaign only works when dialer 1 is active.
When any of the other 2 dialers are active agent based campaign does not work. IVR campaign work fine on each dialer.
I have traced the logs for the malfuctioning dialer and found.
     The dialer try to allocate a port and is unable to do so......and does the same over and over again.
Can anyone please help.
hassan
Re: Problem with Agent based campaign
Hi Hasan,
I am trying to configure IVR based campaign but its not working for me. I have configured according to cisco outbound configuration guide but no luck.
My IPCCE 7.5, CVP 7, CUCM 7 and connection between CUCM to CVP is SIP, CUCM to VGW is SIP. So please help me out to configure the IVR camp for each product. Email: shohag_kuet@yahoo.com
Rashed
Ill do the best i can to help you out.
tell me are you in a live or a lab eviornment? Are you able to agent based campaigns?
Thanks for your reply. This is on my lab. yes i have configured only one agent based campaign. it was working fine but i have deleted coz i was thinking this might me the problem for IVR camp. but still no luck.
So guide me how can i run the IVR camp.
Rashed
225
