09-28-2010 02:52 PM - edited 03-14-2019 06:35 AM
Hello I have a problem I do not get anything from Webview reports only of today, any other days is fine, today I change to work side B as test of redundancy, I get the next error:
13:12:04 Trace: Info: Notification client on pipe 0x21c disconnected.
Last API Error [232]: The pipe is being closed
_____________
-----Distributor---UpdateAW----
13:10:09 Initializing Event Management System (EMS) Library.
13:10:11 Trace: EMS Server pipe <Instancex>\Distributor\uawEMSPipe enabled for <Instancex>\Distributor\uaw
13:10:11 Trace: Release 7.5.1.0 , Build 23684
13:10:11 Initializing Node Manager Library.
13:10:13 Trace: Creating worker threads.
13:10:13 Trace: Real-time feed not active - Sleeping for 5 seconds before retry...
13:10:18 Trace: Real-time feed not active - Sleeping for 5 seconds before retry...
13:10:23 Trace: Real-time feed not active - Sleeping for 5 seconds before retry...
13:10:28 Trace: Real-time feed not active - Sleeping for 5 seconds before retry...
13:10:33 Trace: Real-time feed not active - Sleeping for 5 seconds before retry...
13:10:35 Trace: New trace client: Launcher(upcc) on pipe 0x160.
13:10:35 Trace: New trace client: cmsnode(upcc) on pipe 0x164.
13:10:35 Trace: New notification client: ccdb on pipe 0x16c.
13:10:35 Trace: New notification client: ccdb on pipe 0x170.
13:10:38 Trace: Attempting to connect to local database "omni_awdb"
13:10:38 Trace: Connected to SQL Server 9.0.255 on server HDS01.
13:10:38 EMS pipe: \\HDS01\pipe\ICM\<Instancex>\Distributor\RouterB\EMSServer.
13:10:38 Trace: Attempting to connect to central controller database "omni_sideB" on server "cce02"
13:10:38 EMS message forwarding has started.
13:10:38 Trace: Connected to SQL Server 9.0.255 on server CCE02.
13:10:38 Trace: Starting incremental copy operation.
13:10:38 Trace: Recovery keys: 0.0 (in memory), 574705437219.0 (local AWControl), 574705437219.0 (router AWControl).
13:10:38 Trace: Nothing to do.
13:10:39 Trace: Waiting for new work...
13:10:39 Trace: Starting incremental copy operation.
13:10:39 Trace: Recovery keys: 574705437219.0 (in memory), 574705437219.0 (local AWControl), 574705437219.0 (router AWControl).
13:10:39 Trace: Nothing to do.
13:10:39 Trace: New trace client: conicrex(upcc) on pipe 0x1fc.
13:10:39 Trace: New notification client: ccdb on pipe 0x21c.
13:10:52 Trace: Starting incremental copy operation.
13:10:52 Trace: Recovery keys: 574705437219.0 (in memory), 574705437219.0 (local AWControl), 574705437223.0 (router AWControl).
13:10:52 Trace: Sending message type typeControlMessage
13:10:52 Trace: Sending message type typeUserInfo
13:10:52 Trace: Sending message type typeSkillGroupMember
13:10:52 Trace: Sending message type typeAWControl
13:10:52 Trace: Recovery key: 574705437223.0 (in memory).
13:10:52 Trace: Successfully applied 1 transaction(s) to local database.
13:10:52 Trace: Waiting for new work...
13:10:53 Trace: Info: Trace client on pipe 0x1fc disconnected.
Last API Error [109]: The pipe has been ended.
___________________________________
Distributor rtdist
13:10:11 Trace: EMS Server pipe omni\Distributor\rtdEMSPipe enabled for <instanceX>\Distributor\rtd
13:10:13 Trace: EMT I/O completion ports: max threads=4, concurent threads=0
13:10:13 Trace: Client connection to preferred Real Time Server is initialized.
13:10:13 Trace: Client connection to backup Real Time Server is initialized.
13:10:13 Initializing distributor. Sitename: hds01.
13:10:14 Preferred Real Time Server is [cce01]/[40007].
13:10:14 Backup Real Time Server is [cce02]/[41007].
13:10:14 Trace: RealTimeServer client connection is initialized.
13:10:30 Synchronizer is unable to establish connection to peer.
Last EMT Error [10060]: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to
respond.
13:10:35 Backup feed established from [cce02]/[41007].
13:10:35 Feed activated to client at [hds01]/[127.0.0.1].
13:10:37 Trace: Backup DB restored.
13:10:39 Feed activated to client at [hds01]/[127.0.0.1].
13:10:55 Client at [hds01.]/[127.0.0.1] disconnected.
anyone can help me?
Thanks.
