Community Member
PROBLEM WITH INCOMING NUMBER IN IPCC ENTEPRISE WHEN TRANSFERRING CALLS
This is my scenario:
  • Two gateways connected via SIP to a CUCM (Users CUCM).
  • Users CUCM connected with Agents CUCM via a SIP Trunk.
  • CTI RP defined in the Agents CUCM registered in the PG and associated with Dialed Numbers.
Imagine A as an external phone, B as an IP Phone in Users CUCM and C as an IP Phone in Agents CUCM.
If A calls B --> B transfers C --> C is able to see A number --> OK.
If A calls B --> B transfers to a CTI RP in the Call Center, call is sent to Agent C --> C sees B number --> NOK.
Do you have any idea about why first calling number is not reaching the agent? Thanks a lot!
Can you brief more on this. What is User CUCM and Agent CUCM ? Are they 2 different Clusters or subscribers in the cluster.
What transfer is done in both the Scenario's. Is it a Blind Transfer or Consult Transfer ? When you say B Transfers to a CTI RP, I hope they are dialing via Hardphone? Have they tried transfering via Agent Toolkit or CAD ? Do you have CVP involved
Senthil
Community Member
Hi Senthil,
Two different clusters, connected by a SIP trunk.
We are trying Blind Transfer.
B and C are Cisco IP Phones. B - the phone transferring the phone - is a User, nor an agent, so he hasn't got CAD.
Yes, Call Center is an IPCEE with CVP.
Thanks a lot!
236
