Quality Management 8.5(2): license not detected
Hi all,
Curently i am deploying CCX 8.5.1 wtih AQM 8.5.2
I already succes instal ccx and QM.
But i'm having trouble when i try to configure QM (post installation)
At "enterprise setting" step, QM cannot detect the license so i can't continue to next step
currently i use premium demo license for ccx. Is it a problem?
Any suggestion will be appreciated
Thx.
Anju Josua
Everyone's tags (1)
Hall of Fame Super Silver
You need QM licenses which need to be applied to UCCX server. Do you have those?
Chris
Hi Chris,
Thanks for your response.
Is there any ohter license that i need except CCX premium user?
Where can i get that license?
Anju Josua
Anju Josua,
Yes, having CCX premium license does not entitle you to QM functionality. You need QM license which also gets applied towards CCX server. you can either get Compliance Recording, Quality Management, or Advanced QM. Here is an example of product part for compliance recording:
CCX-85-A-CR-LIC
Which you can order from Cisco through a reseller, ideally GOLD partner which can provide best discount.
HTH, please rate all useful posts!
Chris
Hi Christ,
Sorry for the late respon
Eventually, i got the license but AQM software still can't detect the license from CCX server
Any suggestion
Anju Josua
Silver
Re: Quality Management 8.5(2): license not detected
make sure the settings under Unified CC Database are correct. Also, you'll need to restart services in QM for the license to be detected.
Brian
Hi brian,
Thanks for the reply
which setting ini CC database that you mean? from the guide i read, AQM detect license from daemon service in CCX.
But the daemon service run well.
and also, how can i restart service in QM?
Anju
Silver
Best thing to do is to reboot the server, then re-run post install.
From memory its in c:\program files\cisco\WFO_QM\bin\postinstall.exe (or similar)
882
