Community Member
Remote monitoring not work after divided into data vlan and voice vlan?
Hi all,
I am currently using CM8.5 and UCCX8.0, and testing the remote monitoring feature
Originally, all CAD, CSD, IP phone, CM and UCCX are in the same VLan, and the remote monitoring works great~
However, after I divided the data VLan and voice VLan in the switch
Seems the remote monitoring feature not working now ...
Voice VLan 3001 - 10.10.1.0
Data VLan 3002 - 10.10.2.0
CM - 10.10.1.10
UCCX - 10.10.1.40
IP Phone A 10.10.1.130
CAD Agent A - 10.10.2.128
* IP Phone PC port connect to CAD Agent A's Computer
IP Phone B 10.10.1.131
IP Phone C 10.10.1.132
- The Agent PC is able to ping all the device in 10.10.1.0 and 10.10.2.0
- UCCX is able to ping the Agent PC and the IP Phone A
Here are the setting of the switch
Switch setting
vlan 3001-3002
interface GigabitEthernet1/0/13
description IP PHONE A AND PC CLIENT A
switchport access vlan 3002
switchport voice vlan 3001
spanning-tree portfast
interface GigabitEthernet1/0/14
description IP PHONE B AND PC CLIENT B
interface GigabitEthernet1/0/15
description CONNECT CM AND UCCX (VM)
switchport access vlan 3001
interface GigabitEthernet1/0/16
description IP PHONE C AND PC CLIENT C
interface GigabitEthernet1/0/17
description IP PHONE D AND PC CLIENT D
interface GigabitEthernet1/0/18
description TRUNK TO ROUTER FA0/0
switchport mode trunk
interface Vlan3001
ip address 10.10.1.111 255.255.255.0
no ip route-cache
interface Vlan3002
ip address 10.10.2.111 255.255.255.0
no ip route-cache
The router setting
interface FastEthernet0/0.3001
encapsulation dot1Q 3001
ip address 10.10.1.29 255.255.255.0
interface FastEthernet0/0.3002
encapsulation dot1Q 3002
ip address 10.10.2.29 255.255.255.0
Am I doing any mistake on the setting ??
Sam
Everyone's tags (4)
1 ACCEPTED SOLUTION
VIP Super Bronze
Re: Remote monitoring not work after divided into data vlan and
I see no reference to a SPAN setup in your switch configuration snippet. Are you using SPAN-based or CAD-based recording? If you're using CAD-based then the workstation NICs need to support 802.1q tagged Ethernet frames. The phone simply forwards a copy of the encapsulated voice VLAN frame down the PC Port and does not strip the 802.1q header. Many PC NICs discard tagged packets by default. You may need to Google how to get your specific NIC to accept tagged frames and pass them to the NDIS stack.
http://www.cisco.com/en/US/prod/voicesw/custcosw/ps5693/ps14/prod_system_requirements0900aecd800e3149.pdf
Please rate helpful replies.
Please check the below link, and try the workaround suggested and see if it works.
http://www.cisco.com/en/US/products/sw/custcosw/ps1846/products_tech_note09186a0080b5e901.shtml
Anand
Community Member
hi,
I had followed the steps and successfully implemented the remote monitoring feature in the same VLan,
However, after I separated the VLan into Voice and Data... seems the remote mon feature doesn't work any more ...
Sam
The following phone settings must be enabled in Unified CM for desktop packet
capture to work:
■PC Port. If this is not enabled, the second network port on the back of the phone will simply not work as a network connection for the user's PC.
■PC Voice VLAN Access. Voice and data traffic can be segregated into separate VLANs in order to best use the networking resources. If the user's PC and phone are daisy-chained, and the voice and data are separated into different VLANS, the c0omputer will be a device in the data VLAN and the phone will be a device in the voice VLAN. If this option is not enabled, no voice traffic will be sent out the second network port to the daisy-chained PC.
■Span to PC Port. If this is not enabled, the phone will not forward any network traffic to the daisy-chained PC.
NOTE: Not all versions of Unified CM have all three options. Enable those that do appear on the phone device configuration.
Please use the below link for more information,
http://www.cisco.com/en/US/docs/voice_ip_comm/cust_contact/contact_center/cad_enterprise/non_release_docs/voip-mon-troubleshooting.pdf
Hope it helps.
Anand Choudhari
Please rate helpful posts..
Community Member
Hi Anand,
all these phone settings had configured already, and work fine in the same VLan environment
But still not working in the separated Data and Voice VLan environment ...
Sam
VIP Super Bronze
Community Member
thanks ~ it works now~
845
