route point problem
Hi, we have an ipcc ( CCM 4.1.3,CRA-IVR 3.5.2,ICM 6.0 agents work with CTIOS ) Problem is that every one two seconds some cti port are missed by the system. Trace on ccm - ConnectionManager - wait_AuDisconnectRequest:NO ENTRY FOUND IN TABLE ( for cti route point on which all calls going )
and the same error for any of cti port
On ICM where -- Translation route timeout
at the same time
  • Contact Center
Re: route point problem
Hi there,
did you check in the MIVR traces? Any error for CTI ports or Route Points OOS?
How big is your translation pool? Are you getting more concurrent calls then the number of translation routes available?
Might be an issue with the RP registration or a problem on the number of requests and ports being available/reused.
Riccardo
Thanks for answer,
CTI ports and Route Points are in service
Where two ivr's for each 125 ports and translation routes ( in ICM )
( calls goes on bouth ivr's - load balancing )
where are call limit in pgw for ipcc and we have only 120 concurrent calls incoming.
please get the JTAPI detailed and MIVR traces from the IPIVR, together with the PG and the CCM and raise a TAC SR on this, hard to deal on this one without seeing some logs.
Riccardo
I encounter similar problems. Do you have any follow-up on that?
Thanks a lot,
Martin
162
