04-25-2006 03:33 AM - edited 03-13-2019 11:42 PM
hi
what is the best way to get a script to ask for a pin number before it will proceed to the next steps?
04-25-2006 04:08 AM
Within CRS Script Editor there is a User Folder with Authenticate User step, this will authenticate against CallManager user db.
Chris
04-25-2006 04:09 AM
Chris
04-27-2006 06:01 AM
how does this actually work, do you have any config steps?
04-27-2006 07:10 AM
The attached script shows the script flow using the "Authenticate User" step. Another method is to store the PIN in a variable designated as a 'parameter' which can then be managed through the application setup within the CRS web administration front-end, if you don't wish to use authenticate against a particular user in the Directory.
04-27-2006 07:51 AM
great thanks
