12-28-2006 10:46 AM - edited 03-14-2019 12:24 AM
I would like to define the "calling number" when forwarding calls to an outside line. I know I could mask the number through the Call Manager but that would not allow me to change the number based on each script I am using.
Solved! Go to Solution.
12-29-2006 07:04 AM
The only solution I can think of is doing this at the cti port level, where you'll configure seperate jatpi groups for each application thus a script. Then configure the external phone number mask on the cti ports to the appropriate one.
HTH, please rate all helpful posts!
Chris
12-29-2006 07:04 AM
Chris
