Sip Dialer with Voice Gateway Using FXO Ports
We have a UCCE lab consisting of a SIP outbound dialer and an h323 2811 voice gateway with 2 FXO ports. The dialer reserves an agent and send the call to the gateway but the call immediately fails with the gateway sending a '404 not found' error back to the dialer. Call attempts straight from a CUCM extension connect successfully through the FXO's. Any thoughts?
IOS Ver - 15.1(3)T4
UCCE Ver - 8.5.4
Gateway Configuration:
version 15.1
service sequence-numbers
hostname LAB-RS-ING_VXML-GW
boot-start-marker
boot-end-marker
logging buffered 50000000
no logging monitor
no aaa new-model
no network-clock-participate slot 1
voice-card 0
voice-card 1
 dspfarm
dot11 syslog
ip source-route
ip cef
ip host mediaserver 10.15.80.83
no ipv6 cef
trunk group FXO-Ports
 hunt-scheme sequential
voice service voip
 no ip address trusted authenticate
 allow-connections h323 to sip
 allow-connections sip to h323
 allow-connections sip to sip
 no supplementary-service sip refer
 supplementary-service media-renegotiate
 signaling forward none
 h323
 modem passthrough nse codec g711ulaw
 sip
  bind control source-interface FastEthernet0/0
  bind media source-interface FastEthernet0/0
  header-passing
voice class codec 1
 codec preference 1 g711ulaw
 codec preference 5 g729r8
voice class h323 1
  h225 timeout tcp establish 3
voice translation-rule 99
 rule 1 /^4/ /334/
voice translation-profile PROFILE_TO_CVP
 translate called 99
archive
 log config
  hidekeys
interface Loopback0
 ip address 172.20.1.1 255.255.255.255
 ip address  255.255.255.0
 duplex auto
 speed auto
interface FastEthernet0/1
 shutdown
 duplex auto
 speed auto
router eigrp 15
 network 10.0.0.0
 auto-summary
ip forward-protocol nd
no ip http server
no ip http secure-server
ip route 0.0.0.0 0.0.0.0 10.x.x.x
control-plane
voice-port 0/0/0
 trunk-group FXO-Ports 1
 supervisory disconnect dualtone mid-call
 output attenuation -3
 no echo-cancel enable
 no non-linear
 no vad
 playout-delay maximum 250
 playout-delay nominal 200
 playout-delay minimum high
 playout-delay mode fixed
 timeouts call-disconnect 5
 timeouts wait-release 5
 connection plar 4930
 description 4930
voice-port 0/0/1
 trunk-group FXO-Ports 2
 no non-linear
 no vad
 connection plar 4198
 description 4198
voice-port 0/0/2
voice-port 0/0/3
mgcp profile default
dial-peer voice 1 pots
 incoming called-number .
 direct-inward-dial
dial-peer voice 2 voip
 session protocol sipv2
 voice-class codec 1
 no voice-class sip reset timer expires 183
 dtmf-relay h245-alphanumeric
 no vad
dial-peer voice 4198 voip
 destination-pattern 4198
 session target ipv4:10.15.80.81
 voice-class codec 1
 voice-class h323 1
 voice-class sip rel1xx supported "100rel"
 no vad
dial-peer voice 301 pots
 trunkgroup FXO-Ports
 description ** MIA Local Calls **
 destination-pattern 305[2-9]......
 progress_ind alert enable 8
 progress_ind progress enable 8
 direct-inward-dial
 prefix 305
dial-peer voice 4930 voip
 destination-pattern 4930
 voice-class codec 1
 voice-class h323 1
 no vad
dial-peer voice 7000 voip
 description Agents
 destination-pattern 7...
 voice-class codec 1
dial-peer voice 9999 voip
 description test agent phone
 destination-pattern 9999
 voice-class codec 1
dial-peer voice 1444 voip
 destination-pattern 1444
 voice-class codec 1
dial-peer voice 303 pots
 description ** LD Calls **
 destination-pattern 1[2-9].........
 direct-inward-dial
 forward-digits 11
 prefix 1
dial-peer voice 302 pots
 destination-pattern 786[2-9]......
 direct-inward-dial
 prefix 786
dial-peer voice 9 pots
 destination-pattern 91[2-9].........
 direct-inward-dial
 port 0/0/0
 forward-digits 11
dial-peer voice 1400 voip
 description Agents
 destination-pattern 14..
 voice-class codec 1
line con 0
line aux 0
line vty 0 4
 login
 transport input all
no scheduler allocate
end
Everyone's tags (3)
1 ACCEPTED SOLUTION
Silver
Do you have trunks setup in
Do you have trunks setup in call manager for the dialer?
Silver
Sorry, I mistakenly marked
Sorry, I mistakenly marked your response as a 'correct answer'.
We do have a single trunk on CUCM for the dialer.
Silver
Is your campaign using CPA?
Is your campaign using CPA? If so, what's the behavior if CPA is not enabled?
I think the best thing to do is to run a trace...
Call Manager > Cisco Unified Serviceability > Trace > Configurations
Select a CUCM server - any subscriber would work.
Service Group - CM Services
Cisco CallManager (Inactive)
Enable SIP Stack Trace and apply to all nodes. Download and install RTMT
Make a bunch of outbound tests and then open RTMT > Trace & Log Central > Collect Files > Check "All Servers" for Cisco CallManager > Next > Next > Relative Range if you made the test calls within the last X minutes, otherwise you can set a From and To datetime. Click Finish and go through your SDL logs and see what errors you find and post them here.
Also, make sure your phone is in the correct CSS in Call Manager
Thanks for the reply Omar
Thanks for the reply Omar.
Correct me if I'm wrong but I thought that, with the SIP dialer, that callmanager isn't involved in the process until a call is connected to live voice to be connected to an agent. We seem to be seing the failure happen between the dialer and the gateway: The dialer sends a request to the gateway to place the call and the gateway ocmes back with a 404 error code.
-Mike
679
