Some doubts on UCCE CVP comprehansive call flow.
hi,
What is the configuration on CVP that forwards call to ICM.
as i am not able to find any configuration in OAMP or CVP that target to ICM.
the flow is as follows-
VG-CUSP-CVP-VRUPG-ICM-CCMPG-CUCM
Thanks and Regards-
PK
2 Accepted Solutions
Chintan Gajjar
Level 8
Level 8
There is no configuration in CVP for this,
at the startup CVP makes connection with VRU PG using GED-125.
once the PG connection is up, then only CVP call server will go up, else its status will be down or partial.
by default, whatever request comes to CVP, it will ask ICM as a new call request. CVP works in tight integration with ICM.
regards
Chintan
Reena Mundary
There is no much configuration in CVP.
In CVP ,ICM subsystem configuration the PORT number you have mentioned is should be same as the PORT number  mentioned in CVP PIM configuration.
and in PIM configuration you should mention the CVP host name.
Through this PORT CVP interact with VRU PG using GED-125 and VRU PG communicate with ICM (Router).
Chintan Gajjar
Level 8
Level 8
regards
Chintan
Reena Mundary
