02-07-2012 09:24 AM - edited 03-14-2019 09:19 AM
I need to know if Speech Connect and SpeechView are going to support other languages apart from US English.
Besides that, I can read that Speech Connect needs the Nuance 9.0 speech engine.Is it included? Must I buy it to Nuance?
Thanks!
02-07-2012 09:56 AM
Are you asking for SpeechView for Unity Connection?
If so there is no need for additional hardware, this is a service level feature with monthly/annual fee where you send the messages offsite for transcription.
HTH,
Chris
02-07-2012 10:48 AM
Speech Connect is the dial-by-speaking-a-name feature of CUC. It only supports US English unfortunately - meaning US prompts, and US pronunciations of names need to be used when you talk to it!
It doesn't even support languages that the old Speech Connect for Unity supported such as UK English, which is annoying.
Principal Engineer at Logicalis UK
Please rate helpful posts...
02-08-2012 01:18 AM
Can anybody recommend me a cheap ASR multilanguage solution? Thanks!
02-08-2012 06:22 AM
For what product? UCCE, UCCX, UCON?
Chris
02-08-2012 06:27 AM
UCCX. Thanks!
02-08-2012 06:31 AM
Only supported ASR engines are what is listed in SRND, everything else would cause you more headache than it's worth and at the end of the day most likely will not work, ASR is not a simple technology to take that risk.
"Nuance, Scansoft, and IBM are the only ASR and TTS providers that have been tested and will be supported"
HTH,
Chris
