Supervisor Remote Monitoring
I try to set up remote monitoring on the CCX, allowing the supervisor to barge in a conversation between agent and customer. I kept on following instructions, but I have the problem that in the index Remote Monitor no supervisor listed, so I can not make adjustments.
I work with the ccx version 8.5.1.11002-22.
Here the instruction guide
http://www.cisco.com/en/US/products/sw/custcosw/ps1846/products_tech_note09186a0080b5e901.shtml
Picture with the configured supervisor
Picture of the RmCm -> Remote Monitor Settings
Have anyone an idear ????
Ben
11 Replies 11
anchoudh
Level 9
Level 9
Hi Benjamin,
You Supervisor ID has to contain only numbers (for exampls: 32456) for remote monitoring.
Hope it helps.
Anand
Pls rate helpful posts !!
You mean that my supervisor ID composed of number, like telefonnumber for example and must not be in the form of  names may be ???
Yes for Remote monitoring the Supervisor ID has to contain only the numbers (like telephone numbers). Once you create an ID with numebrs only with Superviosr capability, you will see this Superviosr under remote monitoring.
Hope it helps.
Anand
Please rate helpful posts!!
Ok, I'm going to create a new supervisor, and then I hope to see the settings. Once I adjusted the settings it should be fine ? Currently, I still get the following error message, when I would monitor a call.
Hi Benjamin,
Please use the below link to troubleshoote this issue.
http://www.cisco.com/en/US/products/sw/custcosw/ps1846/products_tech_note09186a0080b78107.shtml
Hope it helps.
Anand
Please rate all the helpful posts by clicking on the stars below each of the right answers !!
Hi Benjamin,
Just thought of getting an update on this issue,
Were you able to get this Remote monitoring working?
Anand
Hi Anand,
the config was not the problem. The problem is the client. We use win 7 64 bit and this system does not support monitoring an recording from CAD.
Ben
Hi, in the config guide it mentions a start monitor step, do you know if I need to include this in my script or is it in the rmon.aef script - it just doesnt seem clear to me?
Many Thanks
Hi Paul,
Its present in the rmon.aef script only.
Hope it helps.
Anand
Excellent - many thanks
Paul Austin
Field Engineer
Capita IT Services
Ellismuir Way
Tannochside Park
Uddingston
Glasgow
G71 5PW
07769 165019
Paul.austin@capita.co.uk
www.capita-its.co.uk
Part of The Capita Group plc
www.capita.co.uk
Hi Paul,
Please rate the helpful posts also.
Anand
