System backup solution for IPCC
There is database backup solution for IPCC. However, is there any backup solution in system level? For example, should a PG crash, we could restore the PG from backup without re-installation.
Any suggestion?
Johnson
Re: System backup solution for IPCC
As PG has no database on it, you could use any disk/partition imaging solutions for backup, like, Norton Ghost, Acronis TrueImage.
Wei
HI
yes PGs dont have any Databases . As I am also working on this recovery plan . for ICM i used icmdba for configuration backups . About using imaging software you can use it to take image of operating system . but beware of this that sometimes during image taking process you might get your hard disk failures .
Irfan
199
