Attention: The Community will be in read-only mode on 12/14/2017 from 12:00 am pacific to 11:30 am.
During this time you will only be able to see content. Other interactions such as posting, replying to questions, or marking content as helpful will be disabled for few hours.
We apologize for the inconvenience while we perform important updates to the Community.
System IPCC and IP IVR Integration
Hi, at the moment i'm working with System IPCC v7.1.5 integrated with CUCM 6.1.2 and IP IVR 5.0.2.
i have completed the servers roles comfigurations and i can see PIM processess for IP IVR and CUCM are up and running, so to test the integration i configured:
on IP IVR
under subsystems ICM> ICM port 5000 and IP IVR scripts
under unified cm telephony cti ports
under applications a translation routing application with as many RP as CTI Ports
on SIPCCE:
1. Dialed Number 3230
2. Call Type and associated already to dialed number
3. skill group
4. Agent associated to skill group
then on CUCM
1. RP 3230 (associated to user rmcm) seems registered to PG A and if PG A goes down keeps registered with PG B
then i have created the ICM script which is as well scheduled with the call type previously configured
the nodes are:
start > select LAA > Skill group
and if select fails then >run ext script.
when i call triguer 3230 the call is sent to skill group as long as agents are available, but if no agents available the call just is not routed, as i can see the ICM is not sending the call to VRU.
i think i may be causing a loop on the configuration can any one helpme undestand what is going on?
Re: System IPCC and IP IVR Integration
Hi there,
add a MED to queue the calls if there are no agents available, otherwise you are looping through the scripts with no agents available.
Riccardo
i found the solution.
under the network vru configuration i was pointing to the same 3230 dialed number, now i changed it to 1250 (the first trigger of the translation routing application) and seems to be working.
Now i have two new issues, 1, reports on web view are empty even when i have tried inbound calls, and if a call come into the queue script cause no agents are available and then the agent is set to ready, the call is not routed to the agent, but istead remains in queue until droped, any ideas?
154
