system is offline. login will be queued until system is backonline
Dears,
Since posting my problem on the forum is fasted than a tac response, i prefered to post it here.
i know that this problem was faced before, but i checked the previous posts with no resolution.
when i try to login into the ctios agent i get the message: system is offline. login will be queued until system is back online.
the ctios server log is showing:
clientMgr[1]:onConnectionClosed, Client[00002]
XXX RCV Client[00002]: eOnConnectionClosed
Client[00002[: HandleI0: Connection closed.<ERROR_NETNAME_DELETED> ERROR:
0x00000040
normally there are two ctios servers A and B. but i shut sideB and just tried with the A. both cti, and ctios servers are up. but i'm not able to connect.
please help.
Re: system is offline. login will be queued until system is back
are your CG and CTIOS services active? Do you have your ctios client to connect to either side??
david
yes both services are up and ctios is listening to port 42028
thanks for your reply
bring up telnet and try to connect to IP 42028 and let us know what happens. Try this connection from the agents PCs.
david
thanks a lot david for you help, the problem was that the jtapi plugin was not installed on the PG.
the problem was that jtapi wasn't installed on the pg. regards
600
