System TTS reading speed - UCCX 8.5
Hey Guys,
I'm looking for a way of slowing down the reading speed of a Float variable when using the the prompt shortcuts: N[FloatVariable].
Can anyone comment if this is possible or if not if this can be achieved through other means?
G
1 ACCEPTED SOLUTION
Re: System TTS reading speed - UCCX 8.5
What you are calling TTS is actually just a directory full of pre-recorded words and sounds.
True TTS would be like a Nuance integration with a Premium license.  And I'm positive you can control the speed and pitch with Nuance.  That's can get expensive though.
At any rate, if you are playing back a dollar amount, the best you can do is break up the audio yourself, and play each token with a customizeable delay inbetween.
Here's what I mean:
Play Prompt (N[10] + DP[500] + SP[gen/currency/usd] + DP[500] +sp[gen/currency/and] + DP[500] +N[3] + DP[500] +sp[gen/currency/cents])
Of course it's not just that easy.  You'll just need to script two things:
1. You'll need to script a solution which takes a floating point number (with a floor and ceiling) and converts it to its many parts, separating each part with a delay prompt.
2. Figure out where the system prompts are.  E.g., "Dollars", "and", and "cents" (or if localizing, those localized prompts E.g., "Pounds", "and", "pence")
That's the best I got.  Happy scripting!
Anthony Holloway
Please use the star ratings to help drive great content to the top of searches.
Anthony Holloway
Here's what I mean:
Anthony Holloway
Anthony Holloway
Thanks Anthony, Seems excessive just to slow the reading speed but can only work with what the software can achieve right.
Might put in a feature request and see what happens
Thanks again, I better start scripting..
G
No problem. And you're right. We work with what we have. Good luck.
Anthony Holloway
416
