Community Member
Track CALLED numbers in a Script?
I have a script which brings a caller to a menu, depending on what option they press it transfers them to a DN. Is there a way I can track which option has been selected or how many times the call has been transfered to number from this script?
thanks.
Green
Re: Track CALLED numbers in a Script?
Sure - integrate to a database.
Geoff
Community Member
You mean write a record each time? I was looking for something simpler
Community Member
you could use the set enterprise call info step to set one to the Call Peripheral Variables to some value for each different choice/destination. Then you can use the Call Variables report to get this info
197
