TTS for UCCX 9 or 8.5
Hello people!!
We are trying to contact Nuance for TTS, so far we have not had any return of Nuance, tried several times chat / email / web form ...
Someone actually managed adiquirir product? If possible orient how we can contact them ...
Or is there some other TTS compatible with UCCX 9 that you are using.
Att,
Roberto Jr
Everyone's tags (4)
Re: TTS for UCCX 9 or 8.5
That's unfortunate you are having a hard time contacting Nuance.  I would think they would want your business.
The compatibility guide lists which vendors and which of their products are supported:
http://www.cisco.com/en/US/docs/voice_ip_comm/cust_contact/contact_center/crs/express_compatibility/matrix/crscomtx.pdf
Here are the two links Cisco provides us for contacting/learning more about the vendors:
Cisco Unified CCX Voice Browser (using VoiceXML), automatic speech recognition (ASR), and text-to-speech (TTS) best practices. For specific information on these topics, refer to the Nuance Communications Inc. website at http:/​/​www.nuance.com or the IBM Websphere Voice server web page at http:/​/​www-306.ibm.com/​software/​pervasive/​voice_server/​
Source: UCCX SRND, Preface, Scope
Anthony Holloway
Please use the star ratings to help drive great content to the top of searches.
Anthony Holloway
Hi Anthony!
Many thanks for the help, It seems that IBM has discontinued its software, we are trying to use Nuance. Inside the "Cisco Unified Contact Center Express (Cisco Unified CCX) Software and Hardware Compatibility Guide" I found the link http://network.nuance.com/portal/server.pt ... try contacting them, meanwhile our client will wait = /
I hope that does not answer the Nuance is not a prejudice for being Brazilian
Tks for help Anthony,
I would contact a reseller of the product (Nuance that is) such as Diagenix.
Hi Roberto,
I´m having the same problem. Do you got the contact with anybody at Nuance?
Carla
715
