Users might experience few discrepancies in Search results. We are working on this on our side. We apologize for the inconvenience it may have caused.
UCCX 5.0 Recording Script, Prompts being deleted by engine
UCCX 5.0(1)SR02
Hi everyone, got a wierd issue/feature. I have written a script to record, blank and revert prompts, it was all working ok until I went back a couple of days later and found all the prompts I had recorded but weren't there orignally had been deleted and the ones I had recorded and then changed had reverted back to the old pre recording prompts.
I also noted that the prompts don't show up listed under the "Prompt Management".
Any one got any ideas what is going on and what I can do to get around it.
1 REPLY
Re: UCCX 5.0 Recording Script, Prompts being deleted by engine
Anyone have any ideas? I have had two clients have the exact same issue, prompts mysteriously disappear and others revert to previous copies. The last client this happened after 4 - 5 weeks.
Frank
220
