UCCX 5.0 - Slow aswering agents
Hello All,
How can I increase the time that takes when the agent receives a call, and the system returns the call to the queue becouse the agent didn't answer?
Many thanks all
1 ACCEPTED SOLUTION
Re: UCCX 5.0 - Slow aswering agents
Hi!
You actually have to open the script that is loaded on your IPCCX application to which your agent is answering.
Inside it, track the Select ressource step and open it. There is a parameter on the bottom of the screen which is named "Timeout" if I remember correctly. This is the time you have to increase.
With best regards,
Chawki
Hi!
With best regards,
Chawki
If you increase this timeout make sure you change the timer on the agent's line for CFNA.
Jason
VIP Super Bronze
Agent lines should not have Call Forwarding configured, especially not to voicemail. This is not supported by Cisco.
Please remember to rate helpful responses and identify helpful or
132
