Attention: The Community will be in read-only mode on 12/14/2017 from 12:00 am pacific to 11:30 am.
During this time you will only be able to see content. Other interactions such as posting, replying to questions, or marking content as helpful will be disabled for few hours.
We apologize for the inconvenience while we perform important updates to the Community.
UCCX 7.0.1(sr4) Oubound Call's Cause Stuck Agent
Opened a TAC case as well -- but wanted to see if anyone else has seen this.
Upgraded from 7.0.1 to 7.0.1(sr4)
The agent CAD upgraded fine on all the desktops - all the agents have local admin.
What's happening is, on an outbound call, if the agent uses the Answer/Drop button in CAD to hang up, they get stuck in "CONNECTED"
It does drop the call, but the agent ends up stuck in CONNECTED and the only choice is logout/login to get the agent state correct.
Anyone else seen this?
Everyone's tags (2)
Re: UCCX 7.0.1(sr4) Oubound Call's Cause Stuck Agent
I had this problem also when I upgraded to SR4 from SR3. After
two days I went back to SR3 and the problem disappeared.
Did you ever get a response from TAC on this issue?
I am seeing a similar issue in SR5.
Thanks.
I'm seeing the same problem with our customer .
Any updates from cisco TAC?
Super Bronze
Ryan from TAC suggested the symptoms for a similar thread may match a known bug (CSCtb77537):
https://supportforums.cisco.com/message/3064699#3064699
Aaron
Please rate helpful posts...
Aaron Please remember to rate helpful posts to identify useful responses, and mark 'Answered' if appropriate!
865
