UCCX Calls answered by IP Communicator but by CAD, no audio
Hi all - have an issue with agents using IP communicator  and CAD.  When a call is routed to an agent and
they answer the call by CAD, there is no talk path audio.  If they answer using their IP Communicator when
a call is routed to them, then they have a talk path - so there is something out of sync with the call control
between CAD and their IP soft phone - where is a good place to start?  would this be in the agent/end user
profiles in UCM where profiles are associated to an agent?  (ie CTI control of device, UCM user, etc?)
Mike Kana
HI Mikekana,
Please ensure that the Span to PC  port is enabled on the IP phone settings in CUCM for the hardphone.
Also make sure that proper ip address of the Network Adapter is selected under the CAD config setup,
by running the PostInstaller.exe from the CAD client box,
(C:\Program Files (x86)\Cisco\Desktop\bin)
Please refer the "Qualifying Ethernet Cards for Cisco Agent Desktop Monitoring" in the below link,
http://www.cisco.com/en/US/products/sw/custcosw/ps427/products_tech_note09186a00801f42f9.shtml
Hope it helps.
Anand
Please rate helpful posts !!
Hello
Thanks for the tips - I checked all the above and did find the span to pc port was not
enabled so I corrected that.  I went through the CAD install guide and found
for ip communicator, the device name  for the phone was not the MAC address
of the PC running the communicator.
I am in the process of changing that device name to the MAC address (preceeded
by SEP) although the devices are stored in active directory and have to work
with resources to change the name.  Changing on my own generates a DB error
when launching ip communicator.  That is the next thing Im going to correct as
this could be another issue with IP Communicator having the voice path while
CAD does not.  Are there any other attributes to check though beyond that?
Thanks Again for your help
Mike
Hi Mikekana,
I don't see problem now, if you are able to get voice in IPC , CAD will also get it.
Anand
Please rate all helpful posts by clicking on the stars below the helpful answers !!
Stupid question - did you run
Disregard.
Hi MikeWe experience the same
Hi Mike
We experience the same issue here. Can you share your solution?
Fei
1108
