UCCX7.0 Supervisor Desktop 6.6(1) Barge-in greyed out problem
Hi all
I have installed the CCX7.0 Supervisor Desktop 6.6(1),
and i can see all the agents status ...
The problem is ... when an agent is on call, i will like to barge-in the conversation
after I selected the Agent
the barge-in and intercept buttons are still grey out,
Am I missing any setting in CM or in UCCX ??
Sam
Everyone's tags (3)
1 ACCEPTED SOLUTION
Super Bronze
Re: UCCX7.0 Supervisor Desktop 6.6(1) Barge-in greyed out proble
First thing - I think you need to click the actual call that the agent is on (i.e. click the + next to the agent, then click the 'Inbound' call).
Also if the agent is in a non-talking state (hold, multiple calls, etc, or if your phone is not on-hook) it won't work.
Aaron
Please rate helpful posts...
Aaron Please remember to rate helpful posts to identify useful responses, and mark 'Answered' if appropriate!
Super Bronze
Aaron
I found my problem is ... the IP phone 7960 not support barge in function,
I have changed it to use the 7970,
Hi Aaron you are right ~~ I selected the wrong place,
I need to select the "inbound" tag
thanks ~~
1118
