Using System Prompts
I am creating a script and would like to use some of the built in recordings under the Program Files\wfavvid\Prompts\system\G711_ULAW\en_US folder. I've tried just referencing them by name but it appears the system only looks to the User prompts repository. Does this mean I'll need to upload essentially copies of all the system prompts to the user prompts folder?
UCCX 7.0SR5
~~~ Rate helpful posts Blog - http://tripplehelix.net
1 ACCEPTED SOLUTION
Re: Using System Prompts
When playing system prompts you would use the convention: SP[promptname.wav]  versus P[promptname.wav] that you use when playing a user prompt.
HTH.
Bill
HTH -Bill (b) http://ucguerrilla.com (t) @ucguerrilla
1 REPLY
HTH.
Bill
301
