VG and CUSP communication issue
Dear Networkers,
We do have UCCE 8.5 with CVP 8.5 in a h.323 comprehensive model deployement.
We are planning to change the signalling method from H.323 to SIP.
We installed two SIP PROXY servers (2x 2951 with NME CUSP), but we're using only one now. After configurin the CUSP and the VGs, calls are failing to get to CVP. It seems that there is an issue between the VG and the CUSP.
We activated CCSIP and ISDN Q931 traces on the Gateway (@IP 172.20.10.240).
CUSP @IP is 172.20.10.25
It seems that the GW can't negociate the codec, i think. But the codec is explicitly configured under the VOIP Dial-peer.
Can you please help ?
Thanks in advance.
KBPRCCGW01N020#
015133: Jun 29 12:24:39.114: ISDN Se3/1:15 Q931: RX <- SETUP pd = 8  callref = 0x151F
Sending Complete
Bearer Capability i = 0x8090A3
Standard = CCITT
Transfer Capability = Speech
Transfer Mode = Circuit
Transfer Rate = 64 kbit/s
Channel ID i = 0xA9838E
Exclusive, Channel 14
Calling Party Number i = 0x2183, '97157331'
Plan:ISDN, Type:National
Called Party Number i = 0xA1, '1198'
015134: Jun 29 12:24:39.118: ISDN Se3/1:15 Q931: Received SETUP  callref = 0x951F callID = 0x4DE0 switch = primary-net5 interface = User
015135: Jun 29 12:24:39.122: //-1/xxxxxxxxxxxx/SIP/Event/sipSPIEventInfo: Queued event from SIP SPI : SIPSPI_EV_CC_CALL_SETUP
015136: Jun 29 12:24:39.122: //171421/3B03E2A98DDE/SIP/Error/sipSPI_ipip_set_history_info_header: Not SIP2SIP mode
015137: Jun 29 12:24:39.122: //171421/3B03E2A98DDE/SIP/Event/sipSPICreateRpid: Received Octet3A=0x83 -> Setting ;screen=yes ;privacy=off
SIP: (171421) Group (a= group line) attribute, level 65535 instance 1 not found.
015138: Jun 29 12:24:39.122: ISDN Se3/1:15 Q931: TX -> CALL_PROC pd = 8  callref = 0x951F
015139: Jun 29 12:24:39.622: //171421/3B03E2A98DDE/SIP/Event/sipSPICreateRpid: Received Octet3A=0x83 -> Setting ;screen=yes ;privacy=off
015140: Jun 29 12:24:39.622: //-1/xxxxxxxxxxxx/SIP/Error/HandleUdpSocketWrites: Send failed errno 261
015141: Jun 29 12:24:39.622: //-1/xxxxxxxxxxxx/SIP/Error/act_socket_send_msg_failure: Send Error to 172.20.10.25:5060 for transport UDP
015142: Jun 29 12:24:39.622: //-1/xxxxxxxxxxxx/SIP/Error/sipSPIGetContentQSIG: No Inbound Container Created !!!
015143: Jun 29 12:24:39.622: //-1/xxxxxxxxxxxx/SIP/Error/sipSPIGetContentQ931: No Inbound Container Created !!!
015144: Jun 29 12:24:39.622: //-1/xxxxxxxxxxxx/SIP/Event/sipSPIEventInfo: Queued event from SIP SPI : SIPSPI_EV_CC_CALL_DISCONNECT
015145: Jun 29 12:24:39.622: //171421/3B03E2A98DDE/SIP/Call/sipSPICallInfo:
The Call Setup Information is:
Call Control Block (CCB) : 0x69397868
State of The Call        : STATE_DEAD
TCP Sockets Used         : NO
Calling Number           : 97157331
Called Number            : 3188
Source IP Address (Sig  ): 172.20.10.240
Destn SIP Req Addr:Port  : 172.20.10.25:5060
Destn SIP Resp Addr:Port : 172.20.10.25:5060
Destination Name         : 172.20.10.25
015146: Jun 29 12:24:39.622: //171421/3B03E2A98DDE/SIP/Call/sipSPIMediaCallInfo:
Number of Media Streams: 1
Media Stream             : 1
Negotiated Codec         : No Codec
Negotiated Codec Bytes   : 0
Nego. Codec payload      : 255 (tx), 255 (rx)
Negotiated Dtmf-relay    : 0
Dtmf-relay Payload       : 0 (tx), 0 (rx)
Source IP Address (Media): 172.20.10.240
Source IP Port    (Media): 16810
Destn  IP Address (Media):  -
Destn  IP Port    (Media): 0
Orig Destn IP Address:Port (Media): [ - ]:0
015147: Jun 29 12:24:39.622: //171421/3B03E2A98DDE/SIP/Call/sipSPICallInfo:
Disconnect Cause (CC)    : 38
Disconnect Cause (SIP)   : 200
015148: Jun 29 12:24:39.626: ISDN Se3/1:15 Q931: TX -> DISCONNECT pd = 8  callref = 0x951F
Cause i = 0x80A6 - Network out of order
015149: Jun 29 12:24:39.802: ISDN Se3/1:15 Q931: RX <- RELEASE pd = 8  callref = 0x151F
015150: Jun 29 12:24:39.806: ISDN Se3/1:15 Q931: TX -> RELEASE_COMP pd = 8  callref = 0x951F
Hi ,
Can you also run the debug CCAPI logs and find is it picking the correct dial-peer.
Also check the reachability to the you CUSP and try to telnet the port 5060 towards cusp ip
Senthil
Have you enabled the
SIP2SIP
under "voice service voip" in the GW ?
This could be good to have as well:
header-passing
//Björn
672
