'Work Not Ready' - 'Work Ready' states in UCCE
Hello all,
I've noticed that my Skill Group and Agent Skill Group dont show the real WorkNotReadyTimeToHalf and WorkReadyTimeToHalf data. The agents are constantly using these buttons on their desktops but all I see is a few seconds on the reports. I also track these events on Agent State Trace table so they do use these buttons very frequently.
Is there something that I forgot doing on configuration?
Thank you in advance
Re: 'Work Not Ready' - 'Work Ready' states in UCCE
Not sure if I followed you completely. Is this happening on webview? or?
Both, since I checked the DB, I'm sure it's the same on Webview
Might be CSCsa27237. What is your running ICM release? Did you try going for the latest SR already?
Riccardo
If the agents works whit multiples skills, an agent may be in workready state for a skill and worknotready for another.
Green
I don't think that's possible.
Geoff
Thank you all,
I opened a TAC case last week, I checked out the bug, I will try the workaround tomorrow. I really hope the workready-worknotready time is calculated in the overall Handle time. I just need custom reports then.
Will keep you updated.
Thank you
1005
