Intermittent disconnects with 1000V
kgarreau
Ok, we have two ESX 4 servers configured right now, dual CNAs connected to two separate upstream switches, 5020-A and 5020-B. We have the 1000V setup what we believe to be the proper way. All of the networking is connected to the 1000V - Service Console, VMotion, NFS, and all the VM VLANs. What we see are intermittent disconnects on our NFS datastores and service console connections 10-20 minutes after we add a second vmnic into the uplink. If we remove one of the vmnics and go back to a single connection, everything returns to normal.
I've included relevant parts from a show run and show spanning-tree from the 1000V... just looking for some insight on where to look next. Thanks.
Nexus1000V# show run
switchname Nexus1000V
vlan 1,60,160,235-236,610,669
port-profile system-uplink
  capability uplink
  vmware port-group
  switchport mode trunk
  switchport trunk allowed vlan all
  channel-group auto mode on sub-group cdp
  no shutdown
  system vlan 60,235-236,610,669
  state enabled
port-profile ServiceConsole
  vmware port-group
  switchport mode access
  switchport access vlan 60
  no shutdown
  system vlan 60
  state enabled
port-profile NXNFS
  vmware port-group
  switchport access vlan 669
  no shutdown
  system vlan 669
  state enabled
Nexus1000V# show spanning-tree
VLAN0001
  Spanning tree enabled protocol rstp
  Root ID    Priority    32769
             Address     0200.0c00.003c
             This bridge is the root
             Hello Time  2  sec  Max Age 20 sec  Forward Delay 15 sec
  Bridge ID  Priority    32769  (priority 32768 sys-id-ext 1)
Interface        Role Sts Cost      Prio.Nbr Type
Po1              Desg FWD 2         128.4096 Edge P2p
Po2              Desg FWD 2         128.4097 Edge P2p
VLAN0060
  Root ID    Priority    32828
  Bridge ID  Priority    32828  (priority 32768 sys-id-ext 60)
lveth3/1         Desg FWD 4         128.1    Edge P2p
lveth3/4         Desg FWD 4         128.4    Edge P2p
lveth4/1         Desg FWD 4         128.1    Edge P2p
lveth4/5         Desg FWD 4         128.5    Edge P2p
VLAN0160
  Root ID    Priority    32928
  Bridge ID  Priority    32928  (priority 32768 sys-id-ext 160)
lveth3/5         Desg FWD 4         128.5    Edge P2p
lveth3/6         Desg FWD 4         128.6    Edge P2p
VLAN0235
  Root ID    Priority    33003
  Bridge ID  Priority    33003  (priority 32768 sys-id-ext 235)
lveth4/6         Desg FWD 4         128.6    Edge P2p
VLAN0236
  Root ID    Priority    33004
  Bridge ID  Priority    33004  (priority 32768 sys-id-ext 236)
lveth4/4         Desg FWD 4         128.4    Edge P2p
VLAN0610
  Root ID    Priority    33378
  Bridge ID  Priority    33378  (priority 32768 sys-id-ext 610)
lveth3/2         Desg FWD 4         128.2    Edge P2p
lveth4/2         Desg FWD 4         128.2    Edge P2p
VLAN0669
  Root ID    Priority    33437
  Bridge ID  Priority    33437  (priority 32768 sys-id-ext 669)
lveth3/3         Desg FWD 4         128.3    Edge P2p
lveth4/3         Desg FWD 4         128.3    Edge P2p
8 Replies 8
sudks
Nexus 1K does not support Spanning Tree Protocol. The 2nd port which you added should be part of the port-channel.
The Spanning tree information below is that from N1K  ? AFAIK we dont have this option.
The Port-channel if connected to the same Upstream switch then it should not have the CDP subgroup option. It can be either on or active or passive mode only.
Robert Burns
+ Post the Interface configuration for each 5020 port where the CNA is attached.
Have you tried manually assigning the sub-group IDs?
As a test, for "VEM 3" for example
With both interfaces uplinked to the 1000v do the following:
int eth3/1
   sub-group-id 0
int eth3/2
   subgroup-id 1
+ After you do this post the output of "show int brief".
Robert
kgarreau
Thanks guys. I will get back to you once I'm able to relay from the customer, I appreciate the help!
-Kenny
Have you resolved this?  I'm having a very similar issue with vPC-HM and would love to see what your fix was.
jasonfmic
I experienced a similar problem which may be related.  There is a current bug where multicast will publish MACs through a non-pinned subgroup.  The current work around is to disable igmp snooping.  Try disabling it globally.  If your issue goes away, you may be hitting bug CSCte44240.
yep, i was hitting that bug too.  unfortunately there is also a bug with disabling igmp snooping.  We found that disabling it, whether globally or for specific vlans did not actually disable igmp snooping in all cases.  cisco confirmed there is a bug.  the workaround was basically to enable/disable it several times and force a system switchover (presuming you have a redundant VSM) until it starts working.    I belive the bug has been fixed, but there has not been a patch/upgrade release date yet
That doesn't sound fun.  Ours seemed to disable without issue.  Do you happen to be running 1000v in production?  We are but only with low impact servers for now.
no, this was in our lab where our company's software gets tested before it moves to production.  unreliable multicast is a deal breaker for our application so i've had to migrate off the 1000v for the time being until its fixed.
