lj
N2K port speed set
My N2K connected to N5K, why some ports can set the port speed, and some cann't set the port speed?
int eth102/1/25     !!!No speed command
(config-if)# ?
  beacon          Disable/enable the beacon for an interface
  cdp             Configure CDP interface parameters
  channel-group   Configure port channel parameters
  description     Enter description of maximum 80 characters
  inherit         Inherit a port-profile
  ip              Configure IP features
  ipv6            Configure IPv6 features
  lacp            Configure LACP parameters
  link            Configure link
  lldp            Configure Interface LLDP parameters
  logging         Configure logging for interface
  mvr-group       MVR interface config
  mvr-type        MVR interface config
  mvr-vlan        Interface MVR Config
  no              Negate a command or set its defaults
  rate-limit      Set packet per second rate limit
  service-policy  Configure service policy for an interface
  service-policy  Policy Map
  shutdown        Enable/disable an interface
  snmp            Modify SNMP interface parameters
  spanning-tree   Spanning Tree Subsystem
  switchport      Configure switchport parameters
  untagged        Default to use for untagged packets on interface
  end             Go to exec mode
  exit            Exit from command interpreter
  pop             Pop mode from stack or restore from name
  push            Push current mode to stack or save it under name
  where           Shows the cli context you are in
(config-if)# int eth102/1/48       !!! include speed command
(config-if)# ?
  bandwidth              Set bandwidth informational parameter
  default                Set a command to its defaults
  delay                  Specify interface throughput delay
  duplex                 Enter the port duplex mode
  fex                    Configure FEX fabric
  flowcontrol            Configure interface flowcontrol
  hardware               FEX Card type
  link                   Configure link
  load-interval          Specify interval for load calculation for an interface
  mac                    MAC
  mac-address            Configure interface mac address
  negotiate              Configure link negotiation parameters
  priority-flow-control  Enable/Disable PFC
  speed                  Enter the port speed
  storm-control          Configure Interface storm control
  vpc                    Virtual Port Channel configuration
  vtp                    Enable VTP on this interface
  end                    Go to exec mode
1,N5K version:
Cisco Nexus Operating System (NX-OS) Software
TAC support: http://www.cisco.com/tac
Documents: http://www.cisco.com/en/US/products/ps9372/tsd_products_support_series_home.html
Copyright (c) 2002-2013, Cisco Systems, Inc. All rights reserved.
The copyrights to certain works contained herein are owned by
other third parties and are used and distributed under license.
Some parts of this software are covered under the GNU Public
License. A copy of the license is available at
http://www.gnu.org/licenses/gpl.html.
Software
  BIOS:      version 3.6.0
  loader:    version N/A
  kickstart: version 6.0(2)N1(2)
  system:    version 6.0(2)N1(2)
  Power Sequencer Firmware:
             Module 1: version v5.0
  Microcontroller Firmware:        version v1.0.0.2
  SFP uC:    Module 1: v1.1.0.0
  QSFP uC:   Module not detected
  BIOS compile time:       05/09/2012
  kickstart image file is: bootflash:///n5000-uk9-kickstart.6.0.2.N1.2.bin
  kickstart compile time:  3/14/2013 1:00:00 [03/14/2013 16:53:55]
  system image file is:    bootflash:///n5000-uk9.6.0.2.N1.2.bin
  system compile time:     3/14/2013 1:00:00 [03/14/2013 19:28:50]
Hardware
  cisco Nexus 5596 Chassis ("O2 48X10GE/Modular Supervisor")
  Intel(R) Xeon(R) CPU         with 8262944 kB of memory.
2,N5K port
Eth102/1/1    --                 connected 101       full    1000    --
Eth102/1/2    --                 connected 101       full    1000    --
Eth102/1/3    --                 connected 101       full    1000    --
Eth102/1/4    --                 connected 101       full    1000    --
Eth102/1/5    --                 connected 101       full    1000    --
Eth102/1/6    --                 connected 101       full    1000    --
Eth102/1/7    --                 connected 101       full    1000    --
Eth102/1/8    --                 connected 101       full    1000    --
Eth102/1/9    --                 connected 101       full    1000    --
Eth102/1/10   --                 connected 101       full    1000    --
Eth102/1/11   --                 connected 101       full    1000    --
Eth102/1/12   --                 connected 101       full    1000    --
Eth102/1/13   --                 connected 101       full    1000    --
Eth102/1/14   --                 connected 101       full    1000    --
Eth102/1/15   --                 connected 104       full    1000    --
Eth102/1/16   --                 connected 104       full    1000    --
Eth102/1/17   --                 connected 104       full    1000    --
Eth102/1/18   --                 connected 104       full    1000    --
Eth102/1/19   --                 connected 104       full    1000    --
Eth102/1/20   --                 connected 104       full    1000    --
Eth102/1/21   --                 connected 104       full    1000    --
Eth102/1/22   --                 connected 104       full    1000    --
Eth102/1/23   --                 connected 104       full    1000    --
Eth102/1/24   --                 connected 104       full    1000    --
Eth102/1/25   --                 notconnec 102       auto    auto    --
Eth102/1/26   --                 notconnec 102       auto    auto    --
Eth102/1/27   --                 connected 106       full    1000    --
Eth102/1/28   --                 connected 106       full    1000    --
Eth102/1/29   --                 connected 104       full    1000    --
Eth102/1/30   --                 connected 104       full    1000    --
Eth102/1/31   --                 connected 104       full    1000    --
Eth102/1/32   --                 connected 104       full    1000    --
Eth102/1/33   --                 connected 104       full    1000    --
Eth102/1/34   --                 connected 104       full    1000    --
Eth102/1/35   --                 connected 104       full    1000    --
Eth102/1/36   --                 connected 104       full    1000    --
Eth102/1/37   --                 connected 104       full    1000    --
Eth102/1/38   --                 connected 104       full    1000    --
Eth102/1/39   --                 notconnec 1         auto    auto    --
Eth102/1/40   --                 notconnec 1         auto    auto    --
Eth102/1/41   --                 notconnec 1         auto    auto    --
Eth102/1/42   --                 notconnec 1         auto    auto    --
Eth102/1/43   --                 notconnec 1         auto    auto    --
Eth102/1/44   --                 notconnec 1         auto    auto    --
Eth102/1/45   --                 notconnec 1         auto    auto    --
Eth102/1/46   --                 notconnec 1         auto    auto    --
Eth102/1/47   --                 notconnec 1         auto    auto    --
Eth102/1/48   ZTC-Switch-48      connected 105       full    100     --
3,Fex
show fex 102 det
FEX: 102 Description: AO4-N2K-FEX102   state: Online
  FEX version: 6.0(2)N1(2) [Switch version: 6.0(2)N1(2)]
  FEX Interim version: 6.0(2)N1(2)
  Switch Interim version: 6.0(2)N1(2)
  Extender Serial: FOX1742G09B
  Extender Model: N2K-C2248TP-E-1GE,  Part No: 73-13671-02
  Card Id: 149, Mac Addr: 64:e9:50:16:08:02, Num Macs: 64
  Module Sw Gen: 21  [Switch Sw Gen: 21]
  post level: complete
  Pinning-mode: static    Max-links: 1
  Fabric port for control traffic: Eth1/3
  FCoE Admin: false
  FCoE Oper: true
  FCoE FEX AA Configured: false
  Fabric interface state:
    Po102 - Interface Up. State: Active
    Eth1/1 - Interface Up. State: Active
    Eth1/2 - Interface Up. State: Active
    Eth1/3 - Interface Up. State: Active
    Eth1/4 - Interface Up. State: Active
  Fex Port        State  Fabric Port
       Eth102/1/1    Up       Po102
       Eth102/1/2    Up       Po102
       Eth102/1/3    Up       Po102
       Eth102/1/4    Up       Po102
       Eth102/1/5    Up       Po102
       Eth102/1/6    Up       Po102
       Eth102/1/7    Up       Po102
       Eth102/1/8    Up       Po102
       Eth102/1/9    Up       Po102
      Eth102/1/10    Up       Po102
      Eth102/1/11    Up       Po102
      Eth102/1/12    Up       Po102
      Eth102/1/13    Up       Po102
      Eth102/1/14    Up       Po102
      Eth102/1/15    Up       Po102
      Eth102/1/16    Up       Po102
Everyone's tags (3)
N2K port speed set
I don't see this behaviour on the Nexus 2248 I have here, though they are the non E model i.e., they're N2K-C2248TP-1GE and not the N2K-C2248TP-E-1GE that you have, so perhaps they behave differently anyway.
The obvious difference that I can see between the two ports you've highlighted i.e., Eth102/1/25 and Eth102/1/48 is that the status of port 25 is not connected, as opposed to port 48 which is up and operational. Is there any other difference? Can you paste a show run interface eth102/1/25 all and show run interface eth102/1/48 all so we can compare?
Do you see the same issue i.e., no speed option, for the other notconnected ports on this FEX? Do they then show the speed option as soon as the port is up and connected?
lj
N2K port speed set
show run int eth102/1/25 all
!Command: show running-config interface Ethernet102/1/25 all
!Time: Tue Apr 14 14:33:38 2009
version 6.0(2)N1(2)
  no description
  lacp port-priority 32768
  lacp rate normal
  priority-flow-control mode auto
  lldp transmit
  lldp receive
  no switchport block unicast
  no switchport block multicast
  no hardware multicast hw-hash
  no hardware vethernet mac filtering per-vlan
  cdp enable
  switchport
  switchport mode access
  no switchport dot1q ethertype
  no switchport priority extend
  switchport access vlan 102
  spanning-tree port-priority 128
  spanning-tree cost auto
  spanning-tree link-type auto
  spanning-tree port type edge
  spanning-tree bpduguard enable
  no spanning-tree bpdufilter
  speed auto
  duplex auto
  flowcontrol receive off
  flowcontrol send on
  no link debounce
  no beacon
  delay 1
  snmp trap link-status
  logging event port link-status default
  logging event port trunk-status default
  mdix auto
  storm-control broadcast level 100.00
  storm-control multicast level 100.00
  storm-control unicast level 100.00
  no shutdown lan
  load-interval counter 1 30
  load-interval counter 2 300
  no load-interval counter 3
  medium broadcast
  channel-group 2025 mode active
  no shutdown
show run int eth102/1/48 all
!Command: show running-config interface Ethernet102/1/48 all
!Time: Tue Apr 14 14:35:08 2009
version 6.0(2)N1(2)
  description ZTC-Switch-48
  lacp rate normal
  lldp transmit
  lldp receive
  cdp enable
  switchport
  switchport access vlan 105
  speed auto
  duplex auto
  flowcontrol send on
  no link debounce
  no beacon
  delay 1
  mdix auto
  no shutdown lan
  medium broadcast
  no shutdown
Ports are connected, there is no relationship with the speed option, such as port 102/1/1 is connected, but no speed option, port 102/1/47 is notconnected, there speed options.
show int eth102/1/1
Ethernet102/1/1 is up
  Belongs to Po2001
  Hardware: 100/1000 Ethernet, address: 64e9.5016.0802 (bia 64e9.5016.0802)
  MTU 1500 bytes, BW 1000000 Kbit, DLY 10 usec
  Encapsulation ARPA
  Port mode is access
  full-duplex, 1000 Mb/s
  Beacon is turned off
  Input flow-control is off, output flow-control is on
  Switchport monitor is off
  EtherType is 0x8100
  Last link flapped 1d02h
int eth102/1/1
(config-if)# ?
  link            Configure link
  end             Go to exec mode
show int eth102/1/47
Ethernet102/1/47 is down (Link not connected)
  Hardware: 100/1000 Ethernet, address: 64e9.5016.0830 (bia 64e9.5016.0830)
  MTU 1500 bytes, BW 0 Kbit, DLY 10 usec
  Encapsulation ARPA
  Port mode is access
  auto-duplex, auto-speed
  EtherType is 0x8100
int eth102/1/47
(config-if)# ?
  link                   Configure link
  mac                    MAC
  end                    Go to exec mode
lj
N2K port speed set
Ok, I think I found the reason, if a physical port has been added to the port channel, duplex and speed option can only be configured in interfce port-channel mode.
Thanks.
622
