Attention: The Community will be in read-only mode on 12/14/2017 from 12:00 am pacific to 11:30 am.
During this time you will only be able to see content. Other interactions such as posting, replying to questions, or marking content as helpful will be disabled for few hours.
We apologize for the inconvenience while we perform important updates to the Community.
Nexus 5500 and FEX Port-channel
Team,
I have been starting to read a lot of this tech but I still have some doubts regarding port-channel limits in my platform.
So this is my current set up:
- 1 Nexus N5K-C5596UP
- 2 Fabric Extenders N2K-C2148T-1GE.
Currently the Fabric Extenders are connected to the C5596UP, and they have been attached correctly, and everything is working fine:
LAB# show fex
  FEX         FEX           FEX                       FEX
Number    Description      State            Model            Serial
110        FEX0100                Online      N2K-C2148T-1GE   FOX123455666
120        FEX0200                Online      N2K-C2148T-1GE   FOX123123234
I have been reading this DOC:
http://www.cisco.com/en/US/prod/collateral/switches/ps9441/ps9670/C07-572829-01_Design_N5K_N2K_vPC_DG.pdf
There I read that:
- There are differences between Nexus 5000 and 5500 mostly because port density of 5500.
- There are something called "index" which have a limitation of 48.
- In 5500 every single port can be a port-channel itself.
- Those index can be used either by using a single port, several ports or bundles of ports.
- If the nexus use one of their hardware ports it will use one index.
- On the other hand, If the nexus doesnt use its hardware ports, It won't use those index.
- The document also describes that if the port-channel just use FEX ports, it won't use an index.
I also read this document that describes limitations of interfaces per bundle up to 16.
http://www.cisco.com/en/US/docs/switches/datacenter/nexus5000/sw/configuration_limits/limits_502/b_Cisco_Nexus_5000_Series_Configuration_Limits_for_Cisco_NX_OS_Release_502_n1_1.html
So after of read that I still have some questions:
1. If I configure port-channels just using fex ports, I wont use indexes but, there are still limitations on it?.
2. How many port-channels can be configured on a single FEX?
3. How many port-channels can be configured if I am using ports that belongs to diferent FEX?.
4. How many port-channels can be configured using hardware ports?
5. How can I check how many available indexes left?
6. There is a limitation of port-channels based on version?
7. 16 ports as limit applies to every port-channel configured?
Thank you for all your support.
Pablo.
584
