Webcast-Catalyst9k
Nexus 5548-UP with N55-M16P
Hi All,
I just want to confirm the following scenario with all you other Cisco guys.
Client has bought a N5548UP switch with a N55-M16P module (NOT Unified), I know on the UP switches that you need to configure the FC ports from the last available port - ie port 32, downwards. I'm assuming this will be ok because the requirement is to work backwards on the slot (rather than the entire switch which might see the last port on the module as the last available port).
In summary, I want to confirm this scenario works:
N5548 Slot 1, Port 1.. Port x (ie 27)... Ethernet
N5548 Slot 1, Port x+1 (ie 28) .. Port 32 .. FC
N5548 Slot 2, Port 1 - 16 Ethernet.
Nick.
Everyone's tags (2)
1193
