OTV VDC Requirement
I've heard some different stories on whether or not a separate VDC is required specifically for OTV functionality, all the material I've seen says 'yes' you should a separate VDC for OTV, but I just wanted to give a shout out on this forum.
Also, let's say I have 2 VDCs (VDC-A and VDC-B) and I wanted both those of those VDC's to be OTV'ed to a secondary data center, would that then require a 2x specific OTV VDCs one for each VDC or can I run two OTV instances within the same VDC providing OTV capabilities for 2 different VDC's?
Thank you in advance.
-- CCNP, CCIP, CCDP, CCNA: Security/Wireless Blog:
OTV VDC Requirement
Hi There
first of all you are right that a separate VDC is required to run OTV and best practice
however this dose not mean you need a VDC per other VDCs, it is just like you creating a virtual appliance servicing you OVT ( encapsulating L2 into L3 OTV header ) then back to your normal network/L3 VDC
all what you need is a L2 link /access or trunk from each VDC need to use OTV ( intra-interchassis ) and a L3 link from the OTV VDC back to your switch in L3 ( for encapsulated traffic )
hope this help
Re: OTV VDC Requirement
Thank you for clarifying that.
Another quick question can my OTV Join interface connect to a Non-Nexus device, the way I understand it it will simply be passing multicast traffic. (I will be configuring multicast transport between my OTV DC sessions) I was planning on connecting the OTV Join interface to an upstream catalyst device, just so I don't have to burn another physical port on the N7k and this way the OTV Join interface is closer to the WAN.
No problem at all, you can connect your join interface at any device L3 capable.
*Be aware about the MTU requirement. (most people forget that).
